Hisun Sector 750 EPS- Valve adjustment at 20 hours
I've read a couple people saying they found em out of spec from the factory. Just got my UTV recently and it's on my list here in the next couple weeks.
As far as tools should be easy: Allen wrench to pull the covers, 10mm box wrench for the lock nuts, a wrench for the adjuster, and a flat feeler gage set.
Pull the fan cover, pull the valve covers and spin it over check, and adjust as needed. The covers use an o-ring that should be reusable. Hardest part is going to be contorting my body to fit.
What size and make is you UTV? Also how many hours on it. Manual says check at 20 hours.
It's a coleman (hisun) 400. the engine/drivetrain & maine schedule seems to be identical to the 550/750s.
It's got a whole whopping 5 hrs on it. I had it for about 10 days before I had to go back to work on my ship. Be back home soon and planned on doing that and the first oil change in a couple more hours run time.
    • By Randyh79
      Is there a way to adjust the brightness of the dash light on aHisun 750 sector?
    • By Randyh79
      Does anyone know how to adjust the headlights on a 2024 Hisun sector /Bad Boy Bandit 750? The high beams are where the low beams ought to be.
      Thanks Randy
    • By packersfan
      I have a hisun 500 got from a auction and when turning a corner left or right it's a two hand job then when you left go snaps back.any help on what to look at would be appreciated.
      Also blows blue smoke until she gets warm then it's ok
    • By Jon C
      Hello to anyone who reads this. I am Jon and I own J&M Outdoor Power, a very small, small engine repair shop. I was approached by Coleman about 6 months ago to become one of their Warranty Centers.
      I recently received 3 different UT400's and a UT500 all with similar issues. These units range from 2 months to 2 years old. Customers state that the unit(s) was/were running fine, then heard a pop and a loss of power, two would no longer start. The two that would run would not achieve normal operating speed (around 20mph I would say) without redlining the RPMs. I quickly found that the Valve lash on each unit had become too large on some(both intake and exhaust) and too tight on one(just intake).
      After setting the gaps to .005(I found multiple different people suggesting bigger and smaller gaps, but no definitive Coleman Spec number yet) every unit starts, runs, and achieves top speed without issue.
      I don't know how many others have come across these issues, and I wanted to get something out on the web for others in the same predicament.
      Please let me know if you have had similar issues.
      Edit: I realize that this will not be a fix all solution for this issue, as the oil level and condition should be verified before moving to the valves. Many times improper oil conditions will cause valve lash to change. These units all have good oil and proper oil changes.
    • By aefron88
      Since I've seen some questions on this I took some pictures and will provide instructions on a valve adjustment for the UT400. This should be the same for the 550's and other various Coleman/Hisun single cylinder models with the cylinder slanted aft.
      I have seen several people ask of it is really necessary, and read several reports of valves being out of adjustment from the factory. My valves were .004" intake, and .010" exhaust with about 5 hrs on the machine.  I've seen different numbers thrown around for factory spec, but I decided to go with 0.005".
      This is called valve lash. What is is is a gap between the rocker arm and the valve then the camshaft isnt opening the valve. Why does it matter? If it's too large the valve doesn't open all the way, if it's too small the valve dosent close. This can cause valve damage (overheating) as well as loss of engine power (burned fuel is going out exhaust rather than pushing the piston dow).
      Tools required : 5MM Allen wrench, 10MM box wrench, needle nose pliers, flat feeler gauge set, rags
      First you need to remove the fan cover on the passenger side. There is a cooling vent hose on the back side, remove the hose clamp and slide it off. From there there are 4x 10mm bolts holding the cover. The forward ones can be accessed from under the seat.
      Next remove the spark plug from the drivers side. Carefully wiggle the spark plug wire off. Grip it as low as possible and give it a little twisting motion as you pull it off to help free it. Its a tight fit for a socket, but there is a sheet metal wrench in the toolkit that fits it. Unscrew the plug and set it aside. This allows you to spin the motor over freely with no compression to fight. When you reassemble this is a good opportunity to switch to an NGK iridium plug for better performance/less fouling DR8EIX)
      Next you need to remove the intake and exhaust valve covers. The intake us the forward one. There are 3x 5MM Allen screws to remove. The Exhaust is the rear with 2x 5MM Allen bolts. Both covers have O-Rings instead of gaskets and are reusable. When you remove the rear be careful and use your rags as there will be oil that drips out.
      Next up we need to spin the motor over to top dead center. Grab each rocker arm and give em a little wiggle up and down. Spin the engine over by grabbing the fan with your other hand. Spin the engine over until both rockers have some wiggle and are loose.
      Once both rockers are loose slide the feeler gauge in like shown above. Try different feelers as needed to determine your starting spec. You should feel some drag but still be able to move the feeler without too much force.
      If you need to adjust, use the 10MM wrench to slightly loosen the locknut, then with the correct feeler gauge in place, tighten the top square nut while wiggling the feeler in and out. Once you have it right you need to tighten the 10mm lock nut without moving the square head bolt. Once the lock nut is tight recheck the clearance.
      That's it, button everything back up and make sure you have it all reassembled before running it again.
      If you find this helpful give me a thumbs up or comment. If you have any questions or need more help let me know. If there's interest maybe I'll do some more of these
