I have a 2013 Massimo MSU 500 project. I just recently got it running after sitting in pieces for an unknown amount of time. I replaced the wet clutch and drum, the primary clutch and belt, the spark plug, ignition wire, and ignition coil. I cleaned the fuel tank, replaced the fuel lines, fuel and air filters. I adjusted the valve lash and  the throttle cable stroke. Now to the problem. It tops out in high gear at about 4400 rpm at 27 mph. It tops out in low gear at 5200 rpm at 28 mph? It will rev to about 7500 rpm in neutral. I'm guessing I just don't have enough horsepower for some reason. Ideas?
No, I picked this thing up for $50. It's the first SXS that I've ever had. Just trying to figure this thing out as I go. No manual or anything. I've got to dig out my compression gauge. It's in this shop... somewhere. lol
Update: I just ran a wide open throttle compression check and it's 135! According to the stats that I dug up it's supposed to be between 163 and 210. So, that's not good. Also when I removed the spark plug it was chalky black with soot. So I've got something else going on, I'm not sure what yet. Grrrr!
No, it wouldn't, but I don't think the low compression would cause the spark plug to soot up. That's a definite sign of running too rich. If one of the sensors is sending an erroneous signal to the ECM it could cause it to run rich.
Well now, that's a good thought. Tomorrow night when I get home I'll redo my compression test and this time I'll add a little oil. If the compression improves, it's rings, if not, it's valves. I new that just didn't think to do it. Thanks!
Okay, so I'm in the process of rebuilding the top end of this machine and I can't find any timing marks on the cam. No notch, no dot, no painted tooth, nothing. Does anyone know what it's supposed to look like?
  • 10 months later...
    • By barticus73
      I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a  Dealer provided CFMOTO Uforce 600 at $11,500 out the door.    Are there any glaring reasons to go with the Uforce 600 at an extra $1000?  Is one model more reliable than the other?  Any input greatly appreciated.
      Thank you,
      Jerry
    • By barticus73
      I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a Dealer sold CFMOTO Uforce 600 at $11,500 out the door.    Are there any glaring reasons to go with the Uforce 600 at an extra $1000?  Is one model more reliable than the other?  Any input greatly appreciated.
      Thank you,
      Jerry
    • By Tim n Deb
    • By Chile
      Chile
    • By Chile
      2018 Massimo MSU 700 EFI. I realize that this engine is essential the same as in all of the HISUN based Yamaha clones out there. I am in the process of performing a top end diagnosis/rebuild. I have an AMAZON top end rebuild kit on order in anticipation of this activity.
      Question 1:  When exploring the myriad of top end rebuild kits on the market for these units there are some cylinder assemblies that have "686 cm3" badging next to the cam cain tensioner boss. Others compatible with the unit do not have this badging. The existing cylinder assy does not have the 686 badging. I am assuming that this simply verifies that the cylinder assy is for a 686 cm3 engine which of course the stock 700 series HISUN engines are. Am I missing something here or is this just a manufacturer artifact? With or without the badging the application listings all indicate compatibility with the MSU 700 series engines.
      Question 2:  I have reviewed at minimum a dozen videos associated with this rebuild. To date I have not found one that deals with piston/cylinder clearance and/or ring gap verification. The advertised specifications for these various "top end rebuild kits" all indicate: Cylnider bore = 102mm and piston diameter=101.5mm. The math yields a .5mm (as in 1/2 mm) difference. That seems to be a very large piston/cylinder clearance.  I realize I am referencing advertised specs rather than emperically measured values but the numbers have gotten my attention.  I have referenced the FSM and found it to be somewhat confusing in this regard. Hopefully the experts on this forum can enlighten me as to where my observations are faulty here.
      Any and all assistance is greatly appreciated .
      Thank you all in advance,
      Chile
