Steveo,
This is a UTV forum so I'm not familiar with the ATVs, but it seems to be. PZ19 CARB. They seem to be widely available small Chinese CV style carbs. You could try a larger main jet and see what happens. They seem to only run $20-30 anyway. If you google "pz19 jets" you can get a full set of different sizes for around $10. There are also some other performance kits that seem to be available.
As far as a starter (I think thats what you're asking?) I don't see one available in the parts diagrams.
  • Popular Now
    • By Jamie 67
    • By AaronD1982
    • By Eman85
      Pulled fuel injector to see if I could clean it or if it's stuck open. Had a slide on clip that was really tough to get off. Don't see how the clip is supposed to lock into the plastic part that the injector slides into. Any videos or pics of injector replacement?
    • By Roger McLean
      Hello everyone.  I just purchased a 2018 Joyner Renegade R2 1100cc UTV.  Does anyone know how to get replacement instrument gauges for this vehicle?  The fuel and tachometer gauges do not work.
      Where would I get a front hood storage replacement cover or lid for the 2018 Joyner Renegade R2 1100cc UTV?  It is missing.  The seller told me the wind blew it off at fast speed.
