2008 3010 diesel fule pressure
By Nathon S.
I have a Bennche 700 EFI Bighorn. I’ve recently been unable to get it to start. After a little troubleshooting I realized my fuel pump was not pumping fuel. This weekend I emptied the gas and replaced it with new. I replaced the fuel pump, fuel filter and fuel injector. I also replaced the battery, spark plug and made sure all my fuses and relays were good. I have confirmed that the float on the fuel pump is not obstructed. The UTV is about 12 years old and has less than 100 hours on it. It has not run in over a year. Not sure whats going on?!? After doing a little reading I'm leaning towards it being an issue with the ECU or perhaps a faulty wire in the wiring harness. Anyone have any ideas on where to start looking or what I could be dealing with? Any help is appreciated, thanks in advance!
By Hugh
Cooling fans are working, I can hear it running once awhile if I can get the engine warm up enough. Thank you for all the help.
Hugh
By Robert B
Going down a 20 deg hill engine is holding UTV back. Then something releases like going into Neutral and makes a loud clacking noise. Have to use brake to slow UTV down. Then once level it shifts back into gear. Have done shift extension does not pop out of gear.
By FloridaMan
I have a 2012 Massimo MSU 500 that died. I found that it didn't have spark and the fuel pump wouldn't run. Checked all fuses and none were blown.
Went through and replaced the ignition coil, HT lead and spark plug. Still no spark.
Thought it could be the fuse/relay box because I didnt' know much about the machine at that point so I replaced it. No spark.
Then I replaced the ECM just because I was running out of ideas. No spark.
I removed the 9 pin connector and hardwired it making sure that they were no wires got swapped. Still no spark.
Then I replaced the wiring hardness. In doing so, I replaced the 9 pin connector with new ones. I made sure all wires were matched up between the engine harness side and the other harness assembly. Still no spark.
I have no other ideas what to do. My fuel pump doesn't kick on and I have no spark. I have 12V on the fuel pump, ignition coil and fuel injector, but no ground from the ECM control. I unplugged the fuel injector and waited for a diagnostic code but nothing ever came in. It makes me think that the ECM isn't powering up. I've checked for 12V on pins 18 (purple wire) and 15 (white and black wire). I also checked for ground on pin 2 (black wire). All are good.
I am out of options here and I have no idea what else it could be. I have all connections redone and are coated with dielectric grease. I've checked all easy things like fuses and making sure I have 12V in the right placed. I would appreciate any help.
By aefron88
