Hi,
Thank you for admitting me to your forum. I have an issue with my Hisun Axis 500. I bought this vehicle last week, the fuel gauge was totally in good condition. Now it no longer indicates the fuel level. There is no longer any current supplying the gauge. I checked the fuses, everything is fine.
The connections seems ok.
Any idea?
I ran the vehicle for at least an hour, may be more. The gauge did'nt change. Still the same, no white bars have'nt change. May be you're right, i dont know about this UTV. I'll keep wondering for the result. One thing for sure, I will carry a tank of gasoline in case of running on empty.
Thanks.
I would keep an eye on it, but at this point you can't really tell if it's not working. There are 6 bars, and almost 8 gallons so it should be something like 1.3 gal/bar assuming the gauge is linear. Most gas gauges tend not to be, in my experience, at least in cars. I have not tried to check the accuracy of my Hisun's gauge.
For trail riding these things should get pretty decent gas mileage, I'm guessing around 20 MPG, so a full tank should be like 150 miles on that machine.
Idling should burn <0.5 GPH.
So you may not have burned much more than a gallon anyway.
Post an update when you burn some more and let us know if it's still having issues.
  • Alex changed the title to Hisun Axis 500 Fuel gauge fault
  • 4 weeks later...
You were right about the fuel consumption. There are two bars left, that mean the gauge is working. Thanks.
  • 6 months later...
  • 6 months later...
My 2021 HS 500 has the exact same display as yours.  I've been wondering the same thing.  Meantime I'm driving around with a gas can in the back.  I've been roaming around for about 2 hours now driving at low speeds no more than 3,000 rpms max, 10-12 kms/h.  Maybe take a little while  longer for the first white light on the fuel guage to go out?  I hope its not malfunctioning as I am 45 minutes from my dealer in New Hamburg ON and have no trailer to haul it around.
  • Popular Now
    • By Burk
    • By Jamie 67
    • By Kierobi
