PICTURES - My UT400 Loves To Smoke...
By Buddee
Any help appreciated!
By buckrub
By Greg Kilgore
By Randyh79
By Jeff j j
I have a 2023 trailboss 750. It has a low rpm and mid rpm miss that won't go away. Took it to a shop and had full service, valves adjusted and a sensor replaced. Think the miss is worse than before. Any ideas?0
