JOYNER CONTACT, Alex
By tim hughes
does any one else have a slipping belt on the hisun ...i put new wet clutch one way bearing new belt, cleaned primary and secondary and still get slight slippage
By BuggyBoy
Hi,
I'm in Australia and need to replace the footbrake pads and cable (weak point if you ask me, bad design), plus might as well get the main brakes done at the same time.
Anyone know an Aus dealer, or, know the parts number or equivalent in the petrol version?
Cheers.
By Michael Wood
I have a 2018 Massimo Buck 400 with 278 miles.
Having issues with my brakes. Took the buggy hunting and when I let my foot off the gas pedal it pulls without pressing on the brake. I looked and the pads on all 4 wheels are all toast. The E-Brake hasn’t been on since I have had it. I am guessing it may be a master cylinder issue because all 4 pads are gone. They all seem to have worn evenly that’s why I think the master cylinder. Just got the machine used from a older couple and they said it sat for some time in there pole barn. Possibly the brake lines? Calipers? I took one brake apart and when I depressed the caliper it didn’t stay. Any help is muck appreciated.
By doncaron
Hello
I have a 2022 Massimo t-boss 550. I’m looking for a fix for my timing problem. It keeps getting out of timing. Now I’m trying to find the proper parts for the linhai motor. I’m looking for tensioner chain and gear. If there’s anything else I can do to fix this issue please let me know. Unfortunately I can’t afford to get something better so I got to get it fixed. Thanks in advance.
Don
By AndySwish33
Brand new t boss 550. couple of questions.
1. Do you need speakers in order to play music ? Hooked my phone to Bluetooth no sound
2. On screen registration.. it won’t let me fill in the info on the touch screen. Navigation works but the registration portion does not
3. Is there a data plan you can get or need ?
thanks everyone
