Trooper cranks but wont start
By Joe Rizo
Hello All,
1. Fuel pump (new)
2. Fuel sensor (new)
3. Fuel injector (new)
4. Battery (new)
6. fuses (12v to all)
13. replaced air filter
By GunnersTacklebox
By UTVLover253
What you love about it
What frustrates you
– Adam
By Paul L
