program will open in old Bud program only/ but will not go in BUDS 2 to let use program ECU problem working on has new engine/ new fuel pump/ injectors/ lines/ sensors/ crank sensor maps/ and new throttle body and injectors. machine starts runs a minute dies/ on 3 rd try says key not recognized /we put other key in and same thing happens/wait 10 minutes, you can go again/ is there a back door in the program/ also might mention unplug temp sensor and map sensor , it will run a few minutes longer / then die again.
I have an Axis 500 and never had any problems until now,it cuts outÂ
at around half throttle. I changed the TPS with no difference, acts like the seatbelts aren't set but can get up to around 15 mph as long as I don't give it too much gas, thanks for any adviceÂ
