By OBL
By AaronD1982
By Fmaxiron
By HighSon
Locking gas door.
Rear view mirror.
Lowered and modified headrest bar for improved rear view. Tailgate protector.
Folding armrests.
Overhead utility rack. Keeps the interior cooler and dryer, too!
Folding rear seats.
If anyone wants links to the rear view mirror, seats, or arrests, let me know and I will post. But know that everything requires some level of fabrication. The utility rack was all custom built. Cheers!
By Mitch13
Gray - seems to carry power
Brown - left turn signal
Pink with red stripe - horn?
Green - head lights?
Yellow - head lights?
Yellow with red stripe?
Blue?
Dark green?
