Anyone know of a US online retailer for the E1 Discover batteries
I've had a battery failure and need one replacement.  The local distributor told me it might take up to four weeks to get one.  I'd like to order one in sooner than that if possible.  Any help would be appreciated.
Thank you for the link.  I have read it in the past and may at some point decide to do the conversion.  My current need is for a single Discover EVGT6A-A that I can order online and have it shipped to me.  This isn't about all the batteries ageing out and needing replacement.  The failed battery was because the connection from the battery to the cable developed a high resistance connection and it literally melted the lead around the terminal and the threaded insert came out.  I have found an "equivalent replacement" on line, but based on the price I believe it to be a lower quality than the Discover.  If given no other option, I may order one and see how it works out.  The Hisun plant in Texas doesn't even have any of these batteries for me to order one through my dealer.
  • Popular Now
    • By Mitch13
      Gray - seems to carry power
      Brown - left turn signal
      Pink with red stripe - horn?
      Green - head lights?
      Yellow - head lights?
      Yellow with red stripe?
      Blue?
      Dark green?
    • By AaronD1982
    • By Eman85
      Pulled fuel injector to see if I could clean it or if it's stuck open. Had a slide on clip that was really tough to get off. Don't see how the clip is supposed to lock into the plastic part that the injector slides into. Any videos or pics of injector replacement?
    • By Timbo
    • By Roger McLean
      Hello everyone.  I just purchased a 2018 Joyner Renegade R2 1100cc UTV.  Does anyone know how to get replacement instrument gauges for this vehicle?  The fuel and tachometer gauges do not work.
      Where would I get a front hood storage replacement cover or lid for the 2018 Joyner Renegade R2 1100cc UTV?  It is missing.  The seller told me the wind blew it off at fast speed.
