trooper fuel tanks sending unit leak
By Kierobi
By Butch
By Jeff freeman
By Eman85
Pulled fuel injector to see if I could clean it or if it's stuck open. Had a slide on clip that was really tough to get off. Don't see how the clip is supposed to lock into the plastic part that the injector slides into. Any videos or pics of injector replacement?
By MilSurpYinzer
Tire chains for the winter
Bumpers because duh.
Thanks so much!
