  • Popular Now
    • By johnney
      it started bogging down when under acceleration.  so first i replaced the carbeurator, no change. now i replaced the wet assembly and no change.  what am i missing. is there a sensor or something im missing. HELP, HELP, HELP
    • By Jarrettj88
      What are the wires on the ignition switch. Like what is the yellow for the red one for the purple one for thanks
      Sent from my VS880PP using Tapatalk
    • By Ztmartin96
      I’m working on a 2011 Bobcat 3400. At around 20mph it bogs down and loses all power. If you let off the gas and let it slow down, it’ll go again until 20mph.
      It use to not do this. Use to run 30mph+ no problem. I’ve replaced the fuel injector, fuel pump, spark plug, and air filter. Cleaned the throttle body, the fuel lines, and cleaned the fuel tank out.
      What am I missing? Any help would be greatly appreciated.
    • By Mark Armstrong
      Hi,
      I am in need of a wiring diagram for a 2011 gray wolf 500. I have searched to no end and cannot find one. Nothing comes on when I turn on the ignition switch. Battery is new and the winch works. I did find a blown 30a fuse on the starter relay and thought for sure I found the problem but still nothing comes on after replacing the fuse and the fuse hasn't blown again since replacing it, I have checked every fuse I can find. Bottom line is I am lost and in the blind without a wiring diagram. Any help is greatly appreciated! TIA!!
    • By juan
      Ball joint for joyner or parts in general
