Help identifying some disconnected components on a Yard Sport YS400
Popular Now
By paul allen
thanks...pa
By Mitch13
Gray - seems to carry power
Brown - left turn signal
Pink with red stripe - horn?
Green - head lights?
Yellow - head lights?
Yellow with red stripe?
Blue?
Dark green?
By KMP
We just bought our 1st side-by-side and wanted to get tips on maintenance items we should address immediately for our 2015 Arctic Cat Wildcat Sport 700 XT. We are truly beginners and welcome any and all suggestions. Thank you, we appreciate your help!
By TimsBrickHouse
By Bigmountainrider
Hi Team,
I'm new to the Forum, and I'm looking for your help. I have a 2009 Yamaha Rhino 700 that has stopped consistently charging. Here are the specs and Info I can provide, the Stator and Regulator are new. The Stator does not have continuity to ground on all 3 wires at the engine bay plug. The stator puts out 15-17AC/V at Idle and 38-39AC/V at 2000rpm at both the engine bay plug and the regulator plug. The Battery regulator plug has Battery DC Voltage, when Running the regulator puts out Charging voltage 13.4-15V. I have upgraded/added ground wires from the primary battery to the engine block, from the stock ground wire bolt on the engine to the Chassis and from the secondary battery to the regulator grounding bolt/ground wire. Now the symptoms are it Charges when first started and will continue to charge while driving or at high idle until the machine returns to idle- it will not charge after that, this includes any RPM. If your shut the machine off and restart the process restarts -it will charge until returned to idle. The Machine has and RM Stator and Regulator and a Kimpex Flywheel. The last time it was driven it had an overheating event- unrelated to charging I think, but worth the mention.
Any thoughts would be helpful, I have the factory Regulator- it was working at the time of replacement- when swapped the same issues occur.
