Where would / must you off-road? Two locations in the mountains and two locations with sand. Also one location you will return to.
Mountains:
Silver City, ID
Ouray, CO
Sand:
Killpecker, WY (going this next summer)
Coos Bay, OR
WILL RETURN TO:
MOAB, UT
rocmoc n AZ
  • 4 weeks later...
Mountains.
Chihuahua, Mexico
Somewhere in Alaska in the middle of nowhere
Sand
Baja Sur Mexico Ciudad Constitucion
Really the entire 1000 miles from Ensenada to Los Cabos. Baja 1000 route
Will Return to
Ocotillo Wells
    • By Firewalker918
    • By 180gtr
      Wheels
      Tires
      Engine
      Transmission
      Axles
      Shocks
      Control Arms
      Throttle Body $90
      Starter $150
      Alternator $150
      fuel pump $70
      Map Sensor $50
      Full set of Guages $150
      Exhaust w cat, O2 SOLD
      Ignition Coil - SOLD
      Wiring harness and ecu SOLD
      That would include....
      Steering shaft, wheel
      Ignition switch, key
      Light bar frame, 2 lights
      misc hardware, spindles
      2 hubs, rotors
      Engine mounts
      Throttle pedal, cables
      Shifter, cables
      Clutch master, pedal
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
