This thing just cracks me up :)
By JWS
Help Please!
Last year my Mule started running bad and was hard to start. NOT a battery or starter problem. I replace the carb with one of those cheap Chinese carbs from Amazon. Problem got worse. So, I replaced the fuel pump, one from Kawasaki, fuel filter and lines. Then replaced the fuel pump line to the engine. Finally bought a Kawasaki carb. Everything was ok till I filled the gas tank with fresh gas then it started running bad and hard to start again. The tank is clean. Gas is fresh, AGAIN. Filter is new. When running it has an occasional misfire. Managed to burn about a gallon out of the tank. Runs better. Replaced the gas cap in case it wasn't venting. No change. When running, if you try to go full throttle, it bogs down. The gas is good. I use it in my mower with no problem. The stater was replaced about one year ago and the flywheel cleaned inside. Still seams like a fuel problem but I'm at a loss. It's going back to the mechanic shop today. We use the Mule every day, live on a farm. It's never sat up. It has 1045hrs on it. New battery and starter.
Any ideas?
By gridlock
I purchased my Hisun Sector E1 three years ago. I think there are a few hundred miles on it, and lots of charging. A couple of weeks ago it started sputtering a lot, not charging fully, and discharging fast. I took a look at the battery compartment under the seat, and noticed this (picture below) which certainly explains a lot!
Questions:
1) Where are those disconnected and corroded wires suppose to go?
2) I took out half the batteries thinking they might be in bad shape, but measured 5.4v on all of them, which doesn't seem bad considering they probably haven't been charging for a while. Do you think I should replace them all at this point (after three years), or just fix the wiring (although I'm not sure what caused that to happen), or they may still be perfectly good? I certainly don't want to put them all back (as I mentioned I removed four out of the eight only to have to remove them again if they are not in great shape.
3) If I do replace them, I noticed there are much cheaper options on Amazon for AGM 6v batteries (Weize GC2 is one option) that are the same size and slightly higher AH than the original Discovery ones. Any thoughts about going with these? I know a lot of folks replaced the AGM with lithuim, but not sure I want to go through the hassle of also replacing the onboard charger, etc. I fine with AGM and getting a few years out of them.
By FTG-05
By NHTracker
I have a 2020 Tracker 800SX LE that I bought new in 2020. Yesterday I noticed two cracks in the bed on the inside corners at the tailgate end. They go all the way through. I use it around the property moving firewood, dirt and stuff. Never put stress on the sides of the bed. Has anyone else had this problem? Is there a fix? Help!!!
By NHTracker
I have 2020 Tracker 800SX LE that I bought new in 2020. Yesterday i noticed two cracks in the bed in the corners at the tailgate end. They go all the way through the bed. I use it around the property moving firewood, dirt and stuff. Don't know how they could occur. Has anyone else had this problem? Is there a fix? Help!!!
