So I'm putting this out there..... I just did a bunch if wrk on a 4x4 truck and the steering was hiem joints! Any reason why it couldn't be fond on the trooper or why it shouldn't be seems like it would be a good upgrade
I don't see any reason why a good heims joint wouldn't work fine. In my opinion, any quality joint would work good provided its sealed from the dirt getting to the joints sliding surfaces. Most heims joints are not sealed and that would concern me. When I redid my A-frame heims joints, I put sealing boots around them to hold the greese in and the dirt out. Dispite heavy abuse, they are just as tight as when I installed them about 1500 miles ago. To assure their reliability, I went to a somewhat larger joint while I was at it.
GOOD Heims are the way to go.....I had them on my mud truck and they last and endure a lot of abuse over tie rods...I think heims are not street legal though. If you are going to reconstruct your joyner steering it would be the way to go....
    • By Skeeter22
    • By mehe
    • By AaronD1982
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
