Need new pistons, rings, connecting rods and bearings for rebuild, dealer cannot get .5mm over pistons. Looking for best aftermarket supplier. Suggestions are appreciated. Thank you
Has anyone found a decent replacement for the factory mirrors on a 2020 1100C? My 2011 1100 and 2020 1100C both have the same mirrors and Kubota hasn't made one improvement to the design during those years. Haven't checked the newer models so maybe Kubota finally woke up. Mine are definitely in need of improvement. .
Greetings to the forum participants, my Kubota RTV 400 has stopped starting. More precisely, it works intermittently. Please advise what could be the cause.
