    • By Rmillerdesigns
    • By JBF
      I bought a pair of Rough Country pod lights and it comes with a 3 pin plug(black, white and blue) I want to hook it up to a lit 5 pin rocker switch but I don’t have a clue what pins do I need to connect it to. I wired it to the keyed switch. Chat GPT as good as it might be does not know what I am asking. Any help would be greatly appreciated!
    • By mark walkom
    • By gridlock
      I purchased my Hisun Sector E1 three years ago.  I think there are a few hundred miles on it, and lots of charging.  A couple of weeks ago it started sputtering a lot, not charging fully, and discharging fast.  I took a look at the battery compartment under the seat, and noticed this (picture below) which certainly explains a lot!
      Questions:
      1) Where are those disconnected and corroded wires suppose to go?
      2) I took out half the batteries thinking they might be in bad shape, but measured 5.4v on all of them, which doesn't seem bad considering they probably haven't been charging for a while.  Do you think I should replace them all at this point (after three years), or just fix the wiring (although I'm not sure what caused that to happen), or they may still be perfectly good?  I certainly don't want to put them all back (as I mentioned I removed four out of the eight only to have to remove them again if they are not in great shape.
      3) If I do replace them, I noticed there are much cheaper options on Amazon for AGM 6v batteries (Weize GC2 is one option) that are the same size and slightly higher AH than the original Discovery ones.  Any thoughts about going with these?  I know a lot of folks replaced the AGM with lithuim, but not sure I want to go through the hassle of also replacing the onboard charger, etc.  I fine with AGM and getting a few years out of them.
