SPOTLIGHT BULBS
By Flanman55
I have purchased a used Supermach700 (2008), It runs great after a new choke cable but. The temp sensor on the thermostat house is unhooked and can not find where it plugs back in. The fan has been un hooked from the sensor in the rad and cant figure out how it goes back together properly. The fan was wired to a by pass switch and i just always leave it on but would like to work it properly. I assume the sensor went bad and not changed.
any help would be great.
thanks
By Paul in Wisconsin
I have a 2023 Tracker 800SX LE that I want to add a sway bar to.
The service manual shows how to remove and reinstall the sway bar.
I called Cabela's to try and get the saw bar. They said they can't get one and the 800SX doesn't have one!!?? Then why is it listed in the service manual?? No answer from them.
Have any of you found a saw bar that fits and what did it cost?
By Marie
By Marie
By Joseph Sills
Has anyone modified the panel lights so they can be dimmed ? I haven't found a wiring schematic for the display .
