As always, more power HELP!
By LongSun
By NDV45
I have 2008 Cub Cadet Volunteer Tracker. Was running fine, parked and next morning electric fuel pump inop. Checked voltage had 4.2 volts. Swapped relays in fuse box, checked all fuses (good) and still low voltage. Does the ECU control the voltage to the fuel pump or which relay controls the voltage to the pump?
Have checked all wiring and not found any place it could be shorted (not saying I may have missed something). I am at a loss. Need Help Please.
By htrotte
While troubleshooting an issue with temp warning light I discovered another temp switch mounted in the pipe going to the head The two switches are literally 6 inches apart. Does anyone know what this third switch is used for? If i can figure out how I will post pictures.
By Buddee
Any help appreciated!
By htrotte
#1 While troubleshooting an issue with temp warning light I discovered another temp switch mounted in the pipe going to the head The two switches are literally 6 inches apart. Does anyone know what this third switch is used for? If i can figure out how I will post pictures.
Author #2 Finally got the pictures took. See the photo and tell me if you know what the switch on the right is.
It looks to be factory and I know the girl who bought it new and she didn't install it.
I can't find anything on it in any manual i have looked at. Any help would be appreciated.
