STARTER
Guest Lenny
I may have one. Had a new one that I sold on Ebay. Guy said it didn't work so I'm refunding his money. I'm thinking it's ok and may just be something simple. Will check it out when I get it back. I'll let you know.
For the starter solenoid you can use a 96 Geo Tracker.. Replaced my solenoid with one. Bolted right up... 1.6 GEO motor ..Make sure you check it out before buying for the starter motor part. I do not know if it spins CW or CCW plus I did not count the teeth on bendix. The solenoid is 78.00 at Advance.. 25.00 For used starter at junk yard.
I recommend the use of an interposing relay when you get things back together, the long run and small wire from key to solenoid limits the current and before I put one on my trooper, I could hear the solenoid come in, but the starter didn't spin, after I put the relay in, no more problems. Take your starter apart and clean and lube it and clean the commutator and then put it back together, that could be all it needs.
  • 5 months later...
Did the interposing relay, but still had problems. So i:
removed starter and dissassembled. water had gotten in and one brush was seized. easy fix.
Who designed the intake? idiot. flipped it upside down. Now, i can get to the starter easily, plus the MAS doesn't get crammed with mud.
Moved the starter cable from the cutoff switch to the battery direct. Why complicate things?
Everything works good so far...
    • By Bassarino51
      My 2014 Odes with less than 1000 miles suddenly won’t turn over with a fully charged battery.
    • By Rizzguy
      Don’t waste your time everybody with rpm motorsports, Omaha. They are people that don’t even work on sxs’s. Trying to tell you how to install things.
      Completely uneducated guy tried to tell me I did not install a mid pipe correctly when it won’t install correctly; that was the reason for the video and the complaint that I called him about.
      This mid pipe has a 1 inch gap at the rear, and the only way to close it up is with a longer bolt, and to stretch the flex at the Exhaust
      After one ride, the rear bolts have disappeared, because how much tension there is on the flex
      And the bolts does not line up at the flange
      Have a video before and after. And they are telling me that it’s my fault because it does not fit
      wtf.!
      What kind of idiotic people are even answering the phones these days.?
      This guy has probably only read a book and never even driven a motorcycle in his life
      Don’t waste your time with this bullshit products
    • By Irons
      Hopefully this helps somebody because I couldn't find any info on this runaway condition.
      Drove 1/2 mile to the gas station and when I started up to leave the starter stuck on. Turn key off starter is still running~! Limp it home wondering what the heck to do, get it in the garage and pull the negative battery terminal to get it to stop. Whew, WTF?
      Calm down and start checking things, starter is hot of course but nothing is smoking and nothing smells burnt. Pull battery cover off and start checking wires from battery to relay and relay to the starter. OK good nothing is hot, nothing is crispy and nothing is melted. Probably smoked the starter though. If this had happened to my wife and I wasn't around the machine would have run until the battery died and probably melted down/burned.
      I'll get to the point to save you folks some time and trouble. Because this is a kymco machine you need 2 different Kawasaki parts to make this repair, and information is scarce to say the least. The switch and a sub harness to connect it to the machine's plug.
      Everything works now, but the starter sounds horrible so I'll be changing that too before spring.
      Good luck out there and hopefully this is just a freak occurrence, but if I were you I'd get rid of this kymco part and put the Kawasaki replacement in now.
      Switch, Magnetic is part number 27010-0767
      Sub Harness Start Relay is part number 26031-Y034
    • By Michael McCandless
      Starter will engage sometimes. Where can I buy a starter and solenoid.
    • By Kingfish
      I've had a battery failure and need one replacement.  The local distributor told me it might take up to four weeks to get one.  I'd like to order one in sooner than that if possible.  Any help would be appreciated.
