Could this be our answer to an engine swap?
Popular Now
By rdc
By rdc
By Butch
By CarlB
I have a 2022 Hisun 750 Sector which comes with a locked rear differential. Was wondering if it would be possible to install an unlocking differential. I see that there are some Hisun made machines that come with the unlocking rear diff, such as Cub Cadet Challenger, some of the Massimos, and probably others. My concern is whether these would be a direct bolt on, using the original axles, drive shaft, and of course matching gear ratio. I've tried to match up part numbers but it seems every brand has their own number system even for parts that I know are identical. If anyone has ever done this swap or has any information about the whether these unlocking rear diffs are comparable to the Sector, I'd appreciate your input.
By MilSurpYinzer
Tire chains for the winter
Bumpers because duh.
Thanks so much!
