PB Blaster to clean off Cylinder head?
Popular Now
By BWF
I have a 2011 or so Landmaster LM200. I cannot get it to start. I turn the key and nothing happens. The brake switch seems to be working, the ignition switch works. The Coil is new the Voltage Regulator is new and the starter relay is new.
I can connect the terminals on the starter relay and it starts right up and runs fine. I just can't get it to start by turning the key.
I am at a loss, please help!
Brad
By Burk
By Jeff freeman
By BigToys
I'm posting this because I couldn't find any like issues, and I have never seen an issue like this in over 30 years.
I got the machine because it wouldn't start. It was only sparking on every 5th revolution. checked the crank position sensor, then 1 at a time cleaned and put dielectric grease on all connectors. I tried starting after each one. Finally it ran. Then after two weeks of starting it everyday, it went back to that spark every 5th revolution. Put in a new coil, and a regulator because it was dropping voltage to the battery while sitting. Of course I had a new plug, checked cam timing and chain, set both valves, and the injector was firing as it should with a perfect spray pattern.
I did a lot more troubleshooting and eventually it got spark every revolution, had great spray, and wouldn't even pop. Stayed this way. It was driving me nuts, wouldn't even pop with ether.
I pulled the trigger on a new ECM because what else could it be? Installed it and she fired right up, and is perfect now. Hope this helps somebody.
BigToys
By Razorair
New to this site I just got this 2014 Coleman UTV 700 High Temp Light on from the start cold I haven't really ohm checked the sensors although they are all new but I have done lots of work on the engine I've replace the head gasket, wet clutch rebuilt the primary clutch and cleaned the secondary clutch with a new belt plus a bunch of other stuff I just can't figure out this high temp light that is on at start and has never been off. I have bled the air multiple times. I also wired a switch for the fan to run it most of the time due to others that have suggested this. It is running good the radiator is getting warm but really haven't ran it enough to make sure it's not getting too hot but I just want the light to work as it's suppose to. I would really like to install a true temp gauge if anybody could help with doing that.
