Slow 2017 HiSun Strike 250
By rdc
By Burk
By HISUN Sector 750 EPS Failu
By Mitch13
Gray - seems to carry power
Brown - left turn signal
Pink with red stripe - horn?
Green - head lights?
Yellow - head lights?
Yellow with red stripe?
Blue?
Dark green?
