If any of Joyner owners are out and about, could you please let me know what your engine RPMs vs Vehcile speed is when you're in 5th gear?  My Renegade sounds like it's wound up real tight when traveling.  For instance, I get about 10 mph per 1,000 RPMs while in 5th gear (45 mph = 4500 RPMs).  Is that normal?  I'm used to lower RPMs.  Other ATVs & UTVs running round my neighborhood that sound like their engine RPMs aren't that high.
Thanks for checking on that for me.  I was afraid I didn't have a 5th gear even though the shift lever was in the 5th gear position.  I just hope my engine doesn't bust a gut traveling fast.  The tach can be a backup speedometer and vice versa.
Thanks again.
  • 4 months later...
I was wondering about the high rpms as well. I love the low 1st gear but wish there was a way to change the rest of the gear ratios. Would sure be nice to be able run along 45 or 50 at about 3000 rpm and not have to listen to a screaming engine. Maybe some day someone will come out with some different gears to change it to.  I have a new renegade 1100 r2
My guess:  I believe the high RPM requirement has something to do with the relatively low torque of the engine itself.  With a higher HP & torque value, the transmission & differential can have lower gear ratios giving better top end speeds at lower engine RPMs.  My 6.0L engine can move my 8000lb van at 65 mph with the engine turning at 1800 rpm..
I understand what you're saying and somewhat agree, but my renegade rpms just turns up to high when traveling down the road. My old 800 cc buggy had half the hp & ran much faster @ much lower rpms. My Renegade 1100 @ 86 hp has enough power to handle longer rpm splits between 3rd, 4th and 5th. I winter in Yuma, AZ. Lots of utv & atv dealers & repair shops around. I'm gonna look around to see if I can find a better geared trany replacement. Has to be some way to add some legs to it & maintain my 1st & 2nd hill climbing gears. Any suggestions or ideas would be appreciated.
    • By Gerald Dillman
    • By GBarney
      Recently bought a 2010 RTV 1100 with bad engine. a d1105T out of a toro 5400 just came available locally. Looking for info on if anybody has installed the turbo version of this engine, what challenges/ problems were encountered, how it turned out.
      Looks like nobody has any insight. I will complete installation and report back as to how it went, how it works, and what's involved.
      Is there a way to bypass the seatbelt speed limiter?
