By donny
Hello I am new here but have had this machine for about 5 years. I am having issues with it surging and sometimes sounding like a small backfire thru the intake. When putting in low, high or reverse it will struggle then go full power then struggle. It will only do the small backfire thing while in neutral reving it many times. Once in awhile it will throw a check engine light.
Parts replaced/checked:
I have checked the valve lashing, timing and adjusted. Parts replaced are the coils, spark plugs, injectors, fuel lines, fuel pump, IAC sensor, TPS sensor, throttle cable, speed sensor, primary and secondary clutch and belt.
By great8redsfan
By KMart
I have a Massimo 400 Buck that overheats and the antifreeze blows out of the motor everywhere! I don’t have to be doing anything but just driving through the field. It only has 26 miles on it. I don’t think the fan is turning to cool the motor. Any ideas how to fix this?
By Michael Wood
I have a 2018 Massimo Buck 400 with 278 miles.
Having issues with my brakes. Took the buggy hunting and when I let my foot off the gas pedal it pulls without pressing on the brake. I looked and the pads on all 4 wheels are all toast. The E-Brake hasn’t been on since I have had it. I am guessing it may be a master cylinder issue because all 4 pads are gone. They all seem to have worn evenly that’s why I think the master cylinder. Just got the machine used from a older couple and they said it sat for some time in there pole barn. Possibly the brake lines? Calipers? I took one brake apart and when I depressed the caliper it didn’t stay. Any help is muck appreciated.
By Kidrock
I got a 2014 bennche bighorn 700 efi it gets fire it’s getting gas but just won’t start up and half way backfires through the air box what would cause that problem I need all help I can get please and thanks
