Hisun dealer support
By Rschrem
By monkthumper
By BigWave
Bigwave
By Gerald Dillman
By Mike Jenkins
I replaced the stator and now it will not start (run). It cranks fine, has fuel pressure, but will not fire up. I replaced the coil, no luck there.
