Massimo 500 questions/parts
Racer310
1-Got  some clicking type noise as if metal to metal and sounds like it is coming from both front and rear A arms. They don't have anything their to grease except maybe take the bolt out and slide back in it?
2-Also manual doesn't give a brand name for the oil filter or a cross reference to buy one at auto parts store.
3-Air filter---where is it? manual I goggled has it in 2 different locations but NO air filter to be found. Maybe it doesn't have one.
4-Love the buggy so far, got LED lights, stereo system, seat covers.......yep and got stuck mugging first time out but had a blast.
Well got the filter/housing  out of buggy (had to loosen the entire shifter/brake assembly). Dude I bought  buggy from lied to me...it was so nasty I was surprised it would even start. Even 5 year old grandson didn't want to touch it.
Dropped oil pan bolt to change oil and it to was nasty, let it drain for awhile while I played with grandson. Can back and has some overspill on driveway. Cleaning the belly pan under motor and a spring with small filter from that belly pan from on ground as I was cleaning. I assumed it came from on top of drain plug. Spring fit in plug with a small screen type filter towards pan and I screwed it in, HOPE that is the way it goes. Had to go out of town to work so I stopped there. Headed this week to Tractor Supply for air/oil filters in my work town. I guess I should check gear case oil as I am being surprised on taking someone else's word for maintenance.
None If I can figure out the noise from A arm front and back, another weekend.
  • 1 year later...
I realize this is a old post but if you are still having the metal to metal noise from the Arms I would check your bushings.  Mine wore out fairly quickly.  I order new ones from an online dealer and they are much better than the stock bushing.
  • 1 year later...
    • By great8redsfan
    • By BOYD
      I have a 2004 KUBOTA RTV 900 DIESEL and I need to replace both front cv axels.I have been online looking at them and there seems to be a lot of different manufactures to choose from. My question is who makes a good aftermarket set of cv axels for this KUBOTA. I have read horror stories of people buying the  cheap Chinese brand only to find out they don't fit or they don't last very long and fail again. I hate to have to spend over $200 a shaft to get OEM from KUBOTA when I'm sure there is a company out there who probably makes it for them or makes comparable to OEM. Thanks for your help.
    • By Ronald
      I just purchased an Axis Pro 750 from Lowes.  I have two questions not covered in owners manual.  1:  In the glovebox there is a 12V connector, it is HOT with key off, is that for a battery maintainer to be plugged in or what is the purpose?  2:  In the instrument cluster there is a digital read out for hours, miles and odometer,  there is also a digital readout that is flashing, it can be adjusted and looks like 1 - 24  what is it?
    • By donwan
      View File 2017 Hisun Strike 900 Service Manual
      Here's the service manual for the 2017 hisun strike 900.
      Submitter donwan Submitted 05/29/2024 Category Hisun
    • By Mark M
      Hello, Hope someone can help driver side cv axle broke anyone know of aftermarket ones you can get, I have 40 Hours on the machine and don't want to pay 450.00 for a new one from cub cadet but I can't find anything after market
