Have 2014 Bennche (Hisun) 700 EFI Four Seater.  Have great difficulty getting out of whatever gear its in.  Very often, have to shut engine off to move gear shift.    Is there a way to decrease idle speed?
  • 2 months later...
it sounds like  a clutch problem to me. I have had bad clutch weights cause this same problem. If you are still having this issue, check out the slider weights in the variator side of the clutch. But it does sound like its clutch related because if the clutch is not fully working, it is telling the engine that the clutch is engaged, causing the big clunk you hear when you try to shift even while not moving. it would also cause the drive line to drag a bit at idle.
  • 9 months later...
    • By nrggaragebuilds
    • By AlphaSerenity
      Hello,
    • By jertex
      I have two questions:
    • By Nick Varnes
