We purchased this UTV less than 60 days ago and now I am having issues with drained battery. Used UTV for about an hour then stopped and when I went to start back up my battery was to low to start it. Jumped it and it started right up and ran fine back home. Tested charging and it’s not charging while running. Can it be anything other than the stater??? Can I look for something that I can fix Quik or does it have to go to the authorized service center to stay under warranty? It will take some time to get it in and out of service
What electrical connection are missing in battery comp? it seems I am missing plug in connections and I am not sure what and how it is supposed to look like. If I can get an image and guidance would be great.
Hello -
New here - and looking hard at a 2026 Mule Pro-FXT 1000. My wife insists we'll be going with the Platinum Ranch, because in her words, we already saved $ by not going with a Honda 1000-6. Ready to pull the trigger on this ... almost.
We were looking at the factory soft cab, but then realized this won't work with the standard hard top, as the soft cab has dual back windows to accommodate the 3/6 folding seats. However, we like the hard top. So recognizing there's a lot available in the aftermarket world, does anyone have suggestions relative to an aftermarket soft cab (sides, rear window, etc.) that will work with factory hard top, windshield and doors - and also allows for a (relatively) simple 3/6 seat conversion?
dogfood
