2001 Kawasaki Mule
Could just need a good carb cleaning. , take off the fuel lines and blow them out with compressed air  to make sure they're clear.
to test coils, get a inline spark tester, hook the clamp to the plug or other good ground on your mule, and crank the engine, if you dont see the light (or  spark, depending on what tester you get) you have a bad coil.
EDIT
here is the link to the troubleshooting guide for your engine : https://www.kawasaki-engines.eu/umbraco/Surface/downloadFile/Download
    • By LongSun
    • By donwan
      I have a part that fell over to the exhaust and burned the harness up. I can't figure out what it is. Does anyone know what the start relay looks like? The part I can't figure out has 4 wires, a red power, a green and brown wire, a black and unsure what the 4th color was. Anyone have a clue?
    • By MOTORHEAD1959
      ATV just clicks when trying to start. Battery is good, has a new starter, and all the wiring looks good. any suggestions on where to go from here? thanks
    • By Steve B
