We unearthed some drawings from an approved patent application for a Kawasaki Sport UTV, which lends some credibility to the long-rumored vehicle. Check out the patent here.
While this doesn’t mean a Kawasaki Sport UTV is guaranteed to be coming to a dealer near you, it is certainly a big step in the right direction for Team Green loyalists who’ve been waiting for Kawasaki to challenge the likes of the Polaris RZR and Can-Am Maverick.
https://www.atv.com/blog/2019/02/check-kawasaki-sport-utv-patent-drawings.html
need large diameter wheels and clearance heigh for any real snow. Of course you don't get any but I used my winch 6x to get back from a trail. The Ranger floor got held up and the wheels just spin
  • Popular Now
    • By AaronD1982
      New starter solenoid....check
    • By AaronD1982
    • By Eman85
    • By Jeff freeman
