Bleeding brakes is generally a 2 man job. One to press the pedal,one to open and close the bleeder valve. Have someone press the brake pedal, and once fluid squirts out shut (tighten) the valve. While tightening the valve keep the pedal depressed, until it is tight. Because if you let off the pedal while the valve is open you risk letting more air in your lines
just dont snap any off...
    • By Hoppy one
    • By AaronD1982
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
