Thanks for the info, i checked it out and all it is in his video is a quick pic of a eps motor he installed then he drives it up a trail saying its really nice to have.
Doesnt tell/show anything about the install.
I have a 2016 Sector 750 and it also has the welded bracket from the factory.  None of the kits I have found account for this as they all seem to include a metal bracket.  The bare minimum you will need are the Hisun EPS motor, Controller (and power), motor to rack coupler, and shorter steering column rod.  I do not know if all of the 2016 models have the EPS controller connector on the harness and the frame mounting points.  Mine does have them under the hood cowling as shown in some of the YouTube videos I have watched.  The kit below has everything needed but also includes the metal bracket that ours do not require.  I am not endorsing that seller or the product, just using it to illustrate the components needed.
https://www.ebay.com/itm/374676885729
Check out this thread
https://www.utvboard.com/topic/7811-adding-power-steering-to-an-r4-questions/
But I reminded you there may be 12V DC power issues. I don't know about the sector 550. But the Axis 500 doesn't generate a lot of extra voltage. There may be power concerns adding any type of Electric Power Steering, OEM or junkyard. The electric power requirements has to be considered. There may be options to increase the electric output with a bigger stator and regulator. But that will take away some of the HP power from the 550 engine due to bigger stator. I know it won't be a lot. But these little engines don't produce a lot of HP anyway.
Good luck. And let us know how it goes.
FYI, For the 2016+ 750's Hisun has a "High output" stator and Magneto rotor available.  I actually swapped to these units myself.  I am also using an Odes Dominator High output regulator/rectifier as well.  I can have my headlights (high beam), 50" light bar, rear pod lights, in cab heater, Wideband O2, my other gauges (5 additional including razorback belt temp), rock lights, in cab lights (high output mirror light and one rock light for foot well) on and I drop from 14.2 ish V to 13.8V.  Considering the factory EPS 750's do not use the high output components to my knowledge, I would not be concerned.  If it does require more power, upgrade the stator, magneto rotor and regulator/rectifier.
So the eps motor would bolt up to that bracket? Do you have any pics of the install?
  • Popular Now
    • By Robert Hamilton
      i am looking for front brake calipers and brakes for my 2008 ruesch xr side by side
      Can anybody help me
      Thanks bob
    • By esmarkey
      Hi, I purchased a used Cub Cadet 750 Challenger that seemed like the belt was slipping so I put a new belt in.  It still acts like the belt is slipping but now I am thinking it is the clutch?
      Can the clutch be rebuilt?
    • By paul allen
      thanks...pa
    • By Burk
    • By Jamie 67
