Thoughts?
stay away from anything you buy at home depot, lowes, etc............get a name brand.........kawasaki, honda, polaris etc.............all that hisun kind of stuff might work, but i have heard getting service is a nightmare..........i have a 4x4 mule, but it is a workhorse, doesn't have what you are looking for......i will tell you this, i never see anything on here related to the mules..........
  • Thanks 1
2023 Maverick X3 X MR Turbo RR
Thoughts on this one?
  • Maverick X3 X MR Turbo RR 64 top features
  • Snorkeled engine air intake and CVT
  • 30 in. ITP Cryptid tires
  • Front bumper, half-doors
  • 4,500 lb (2,041kg) winch with synthetic rope
Sorry guys. She loves this car..I think she would give up me before it..It is incredible. Z51 Perf pkg  Magnetic Air ride    4 suspension modes from tour to track...mid engine ..dual tone exhaust modes..front auto lift for obstacles.6 cameras, 14 speaker BOSE sounds. All in Carbon Flash color. With white Napa leather int.
..194mph top spd.. 10 sec 1/4 .
I'd go for the STINGRAY over any UTV too, but if you can't afford that, I'd run with a CF Moto Z10. They aren't out yet, but for the price and what you will get, the Z10 will be worth waiting for.
And the price for the base unit is only $19,999.99. That's amazing!!!
  • Thanks 1
I suggested Honda. But CF MOTO  also makes quality stuff..I have a C FORCE ATV .Great machine
..Don't buy anything HISUN OR MASSIMO or anything at Lowes, Home Depot or Tractor  supply.. you will regret it..
  • 5 months later...
  • Popular Now
    • By BWF
      I am at a loss, please help!
      Brad
    • By Burk
    • By 180gtr
      Wheels
      Tires
      Engine
      Transmission
      Axles
      Shocks
      Control Arms
      Throttle Body $90
      Starter $150
      Alternator $150
      fuel pump $70
      Map Sensor $50
      Full set of Guages $150
      Exhaust w cat, O2 SOLD
      Ignition Coil - SOLD
      Wiring harness and ecu SOLD
      That would include....
      Steering shaft, wheel
      Ignition switch, key
      Light bar frame, 2 lights
      misc hardware, spindles
      2 hubs, rotors
      Engine mounts
      Throttle pedal, cables
      Shifter, cables
      Clutch master, pedal
