Since my UTV is a slow moving property maintenance work horse and I'm constantly in and out of it, I just buckle the belt up behind me & tuck it in behind seat bottom.
I wouldn't travel quickly or on any roads or on any "tippy" places without the belt on though, too much risk of getting tossed out and maybe crushed that way.
  • Popular Now
    • By Dave Jones
      So with seat belt on  I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
    • By Jamie 67
    • By GNFO
      View File Hisun/Axis seatbelt defeat/bypass
      This file is for using a laser cutter to cut a dummy seatbelt tongue to override the seatbelt warning and speed limiter. I used 3mm thick acrylic. My laser is an XTool, so I included the .xcs file for that brands software, but also included a generic vector file .svg. Probably want to verify the dimensions translated properly for your cutter before using. My UTV is an Axis E1, which is basically a rebranded Hisun Sector E1, and I'm also guessing that all the Hisuns probably use a common seatbelt anyway.
      Use only where appropriate and at your own risk.
      Submitter GNFO Submitted 03/10/2026 Category Hisun
    • By AlphaSerenity
      Hello,
    • By dryvalleyboy
      The steering shaft is slipping,I checked it's tight as the bolt will take at the u-joint.. Is there a slot or something it may have jumped? This is right after the shaft enters the area under the hood.Thanks.
