I think I have tried everything.done a compression test,holding  at 100psi so I don't think the head gasket is blown.Used a raditatior vaccuum to refill radiation to make sure no air bubbles,bled system at motor.Removed water neck and can see center of impeller spinning,I just don't know,am I overlooking something simple? Any advice would be helpful,Thanks
When you bleed the air does it have pressure?  Your pump may not be pumping..I had to replace mine on Hisun 500 engine..also look at recovery bottle..see any air bubbles? If you do, its a gasket failure.
    • By OBL
    • By AaronD1982
    • By Fmaxiron
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
    • By Outlaw Redneck
      Hello all. I have a 2005 Joyner sand spider 650 with the dreaded broken output shaft on the transmission. I got ahold of a 2007 joyner commando 650 for cheap that had a bad motor but a good transmission. I got it because everything i read said that the transmission would work but it seems that it will not. Due to the commando being 4x4 it has a selectable locker and a small ring gear using a "idler" gear to turn the ring gear which make the output spin the wrong direction. Is there any way that I can make this thing work? I really dont want a commando,  I like the buggy but if the trans wont work then I can only put my motor in the commando. Any help would be appreciated. I have the ring gear from the original trans but the shaft is broken and the shaft from the commando wont fit the ring gear it doesn't appear.
