2025 Hisun Stryker 750x, FM radio only receives 3 radio stations
The radio has extremely poor reception, only 3 stations, all above 100Mhz.  I have a cheapo $30 portable that gets 24 stations and a 45-year-old jobsite radio that gets 23 stations, and my truck gets over 35 stations.  Also, the volume is extremely loud on the lowest setting. Any experience with this issue on a new Stryker.?
    • By Firewalker918
    • By Rmillerdesigns
      Hello. I have a 2016 Massimo MSU 500. I was putting on a lightbar and i screwed up and didn't disconnect the battery so when i was taking of the positive cable to put on the power from the lightbar it sparked and now the utv has no power. I turn the key over and all i hear is a chirp. No lights or anything. Everything that comes from the battery to the jumper box up by the battery shows voltage but anything coming out does not such as to the winch or anything like that
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
    • By Dewayne jones
      Just bought new 2024 AODES 650 work cross 2 seated for my dad and he's very resilient at 79 and still cuts trees, splits and hauls firewood for heating home. He's begun using Polaris ATV with wagon more over his 80's toyo4x4 flatbed after the wood has been split. I figured UTV would be easier, more practical at times and more fun. It does not have a heater and would like suggestions on one that best suits his. He's tough but gets chilled easy now and a heater would make joyriding much better at this time of year. I Have found nothing that specifically Says it's made for this particular UTV I don't know what to make of the More generic Hacher versions Or how adaptable they are. I've read They have come from the factory with Heaters but It says nothing about Adding
