Having to replace the fan gears. When inspecting the housing had moisture inside. Looked like there was some oil but don’t know where it gets the oil. I want to protect it but was wondering if I could put grease on the new gears?
  • Brent changed the title to HiSun Axis 500 gear shift fan gears corroded
There was another post on here. It was a shift problem that turned out to be the fan shifter issue like you are talking about.
I don't think that poster put any grease on the fan fingers where they interlock with the gear. Look for that post. There is also a video that he references.
It may be in the Axis or hisun or Coleman sub category. I can remember. But I think there is an oil passage there. Sorry I couldn't give any more help. If you can find that post.aybe you can reach out to that member and see how his solution is working for him. It was maybe a year ago when the post was made
I found the post I was referring to. It on a 2020 Axis that only had reverse and neutral. The title is
2020-axis-500-only-getting-reverse-and-neutral
I'll post a direct link under this reply. This system has to verify a link isn't posted with ill intent. And has to be verified. And I know you want a quick solution. So you can search for the above post title or wait for my link to be approved. It's up to you
Greg, I couldn’t open your link but went ahead and reassembled. However I did take some axle grease and coated the fan gears but wiped off the access.  Don’t think it would hurt. There is an oil path but it doesn’t seem to lubricate the gears fully.  I think this is a design flaw since there are a lot of people (on YouTube) that have experienced the same problem.
    • By dilger
      Transmission vent leaks oil out of it after using
    • By Mountainman
    • By AaronD1982
    • By HighSon
      Locking gas door.
      Rear view mirror.
      Folding armrests.
      Folding rear seats.
