Silent Rider Silencer Update
By AlphaSerenity
Hello,
By HISUN Sector 750 EPS Failu
"Mrs. Smith" doesn't like how loud our Sector 750 is. On a HISUN forum someone said the same thing about his 750. I haven't given it much thought because I've been more focused on stuff that has broken.
So, I used my decibel meter to check ours out. 4000 RPM, Low gear, under 20 MPH . . . . 97 decibels. That's above most ordinances, even state boat noise limits.
AI Overview Ninety-seven (97) decibels is considered very loud and dangerous to hearing with prolonged exposure, roughly equivalent to a newspaper press, a loud nightclub, or a snowmobile. At this level, damage can occur after just 30 minutes, necessitating hearing protection -
By Eman85
By Burk
