So I’d been shopping for an enclosure for my ‘21 TBoss pretty much since I bought it. Then they came out with half doors and that’s the only one that I could find. Then the other day I ran across one on Amazon for half the price of anything else I’d seen. The link is below and I’m pretty impressed by how well it fits. There is one Velcro strap on the top of the door that doesn’t line up well with the roll cage, but I’ll work around it.
https://a.co/d/09ACQ191
Locking gas door.
Rear view mirror.
Lowered and modified headrest bar for improved rear view. Tailgate protector.
Folding armrests.
Overhead utility rack. Keeps the interior cooler and dryer, too!
Folding rear seats.
If anyone wants links to the rear view mirror, seats, or arrests, let me know and I will post. But know that everything requires some level of fabrication. The utility rack was all custom built. Cheers!
