I pulled the valve covers off the mule to adjust the valves. They have been tapping loudly. The two exhaust were correct but the 2 intakes were around .023. But the question is this As I was adjusting I found I could easy open the valve by lightly pressing. Should they should be stiffer than that?
no the spring tension sound about right...
2 hours ago, GDS said:
For the most part, yes and exhaust. At just under 3 bucks for OEM springs I have ordered a new set.
be careful of the rods they bend very easy, make sure there seated all the way.
    • By Sammy
    • By Debbie Hogan
      Debbie fm  Texas
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
    • By Dewayne jones
