Good afternoon wanted to say hello I just picked up a nice 2008 MSU 500 for my kids/teens to drive around. Going to be scouring the forums and bugging a lot of people to get some hopefully easy questions answered. I keep getting told that a lot of the stuff/parts is interchangeable with rhino parts so hopefully that makes things easy if I need to replace items. Thanks for the warm welcome
Sent from my iPhone using Tapatalk Pro
Thanks, its older for sure but I put it through some decent work climbing hills this past weekend. I was impressed. Any things specifically I need to watch for?
Sent from my SM-G988U using Tapatalk
mine as well as several others I have talked to , are plagued with constant overheating issues, resulting in blown headgaskets… and clutch/trans issues ..  Massimo admitted to me in email that these 500 and 700 HISUN engines were not good and they discontinued them, went to another Chinese Company  for engines .. But refuse to help any of us that were dumb enough to buy them.. I bought mine in 2018 new.. its been in shop 5 times , only has 300 miles.. I hope you have better luck. ….oh, and its in the shop right now.... HEAD GASKET
Thanks I’ll keep an eye out. Only issues I know of with 380ish hours and 1300 miles is fuel gauge not working and the winch. It took a beating last weekend and climbed some decent inclines for what it is. Any chance a 700 engine would work? My ecu in the hood says 700-4.
Hopefully the previous owner  got all the problems worked out before you bought it.. .. enjoy it ..When mine actually runs, its fun to drive.. problem has been ,its in 20 minute increments, then back to the shop.. now I m waiting on a new Cylinder head to replace the cracked one mine has ..
  • Popular Now
    • By Kierobi
    • By Eman85
      Pulled fuel injector to see if I could clean it or if it's stuck open. Had a slide on clip that was really tough to get off. Don't see how the clip is supposed to lock into the plastic part that the injector slides into. Any videos or pics of injector replacement?
    • By Rmillerdesigns
