Mule bed
Travis
Okay another project i plan on doing.
The bed has a few rust spots starting on it, so i figure i'd better get the jump on it. Also i've always to put a bed mat in it to protect it, Kawasaki sells one, but for $70 AND it's fairly thin, i think about 5/16" ( i know some of the mats for the newer FXT's are 3/16") maybe less. so here's my plan.
Strip the paint in the floor of the bed, expose raw metal, sand and brush any rust away, apply  POR15 to kill the rust, then once that dries go over with the spray of rust reformer to prevent rust (maybe). Tractor supply sells those horse stall mats, my dad just bought one, they seem to be about 9/16" thick, maybe more. cut to dimensions, ( 40 3/4" wide X 34 1/2" long) Now, the way i figure on fixing the mat to the bed is this:  once i have the mat cut to dimension, drill through the mat and bed and bolt it down with carriage bolts since the heads are more or less flat. do one in each corner, nut and lockwasher on the underside.
ONE quart of POR15 covers 96 SQ FT, so i think a pint may be enough for my bed.....
and it looks like this one will be the right size.... https://www.tractorsupply.com/tsc/product/utility-rubber-mat-black-4-ft-x-3-ft-x--frac12-in?cm_vc=-10005
What should i do differently? Thoughts?
travis  do you have a power dump on your bed ? the horse mats are heavy ....  really heavy,  and the mat may retain water and dirt under the mat.  we just paint ours every other year.  and the other thing about the horse mat is stuff will not slide when you dump them.
No dump assist, I'm pretty strong ;) . Plus, once the angle  of the bed gets to a certain point, the weight assists with the dumping and the tilt of the bed tilts to almost vertical.. But i  rarely carry anything to dump, just firewood in the winter, tools and feed buckets in the spring and fall. I also want something thick enough that can protect the bed from gouges and scrapes, But you do have some good points. I will think about it.
 I also thought about using those spray cans of bedliner.... but i read so many mixed reviews, i didn't know if it would be worth it or not.
Edited by Travis
I like the idea of the stall mat. But if the mule is left out in the weather, then I think water will definately cause problems with rust underneath the mat. If it's kept under a roof, then I think it'll be okay. As long as you can easily pull the mat out. So you'd need some kind of quick connect type fastener.
Because you'll need a way to pull that mat out. You'll occasionally need a way to clean under it. Or to let it dry if it gets wet. But there's always the possibility that if it's heavyweight rubber. That it'll stay in place. No fasteners needed.
Mine has the OEM poly bedliner. It works well enough.
I plan on prepping and coating the bed floor with POR15, supposedly kills and stops rust... It needs it after 20 years.. I thought about water getting under it... I actually cut the mat today and fits perfect all the way around..
I'm thinking about using a black caulk or sealer around the edges. But that would inhibit removal
Right now it stays under a tarp, but a shed for it is in the near future... I
I may come up with a way to use preexisting holes drilled in the bed for load fastening for a quick release though...
Let that mat sit there for a couple weeks. See if you even need it fastened. If you don't use the dump, there should be no reason to need it fastened. And it might just form fit and be fabulous. I guarantee that you'll need to get under that mat. Especially if you fasten it down permanently.
I put a plywood bottom in and old wagon that I pulled behind a four wheeler. That was what I used before the mule. That plywood bottom didn't need to come out often, but it did need to come out.
would not calk it at all, you would need a way for the water to drain out
  • 5 months later...
    • By NHTracker
      I have 2020 Tracker 800SX LE that I bought new in 2020.  Yesterday i noticed two cracks in the bed in the corners at the tailgate end.  They go all the way through the bed.  I use it around the property moving firewood, dirt and stuff.  Don't know how they could occur.  Has anyone else had this problem?  Is there a fix?  Help!!!
    • By NHTracker
    • By Mark T
    • By AndySwish33
      Brand new t boss 550. couple of questions.
      1.  Do you need speakers in order to play music ?  Hooked my phone to Bluetooth no sound
      2.  On screen registration.. it won’t let me fill in the info on the touch screen.  Navigation works but the registration portion does not
      3.  Is there a data plan you can get or need ?
      thanks everyone
    • By Travis
      View File Kawasaki Mule 550,520,500 Complete service manual
      This is a complete service manual for the Kawasaki Mule 500,520 and 550 models.
      Topics  covered include Brakes, Steering, Electrical system, suspension and fuel system. As well as engine repair procedures and Transmission/Final Drive procedures.
      If you need more information about the engine this manual linked below is chock full of information.
      Thanks goes to @cliffyk for getting these files all  into one PDF format for uploading.
      Submitter Travis Submitted 04/18/2021 Category Kawasaki
