By REDfletching
By didgeridoo
By great8redsfan
By donny
Hello I am new here but have had this machine for about 5 years. I am having issues with it surging and sometimes sounding like a small backfire thru the intake. When putting in low, high or reverse it will struggle then go full power then struggle. It will only do the small backfire thing while in neutral reving it many times. Once in awhile it will throw a check engine light.
Parts replaced/checked:
I have checked the valve lashing, timing and adjusted. Parts replaced are the coils, spark plugs, injectors, fuel lines, fuel pump, IAC sensor, TPS sensor, throttle cable, speed sensor, primary and secondary clutch and belt.
