Better gas up the Mule's and Generators!
Popular Now
By Terry B
We purchased this UTV less than 60 days ago and now I am having issues with drained battery. Used UTV for about an hour then stopped and when I went to start back up my battery was to low to start it. Jumped it and it started right up and ran fine back home. Tested charging and it’s not charging while running. Can it be anything other than the stater??? Can I look for something that I can fix Quik or does it have to go to the authorized service center to stay under warranty? It will take some time to get it in and out of service
By kmiller7351
What electrical connection are missing in battery comp? it seems I am missing plug in connections and I am not sure what and how it is supposed to look like. If I can get an image and guidance would be great.
By riggy400
Bought a Coleman 400 UTV (pretty much a Hisun), the previous owner tried to replace the timing chain, couldn't time it properly and sold it to me. After some hours I figured out how the timing all is supposed to be set (I think/hope) and as I am reassembling, I noticed that the water pump gear was awfully hard to spin. I held the gear with my hand and spun off the impeller. I checked the bearing, spins great no obvious issues noticed other than this o-ring which seems to be out of place? When I remove this o-ring and reassemble the WP, it seems to spin nice and easy without a drag. I looked up the service manual (although very inaccurate info there often) and don't see this o-ring present. Am I missing something here or what? Any input?
This is not easy to access once the engine is back in the machine so would like to avoid having to deal with this if it becomes a problem.
By MitchSpence
I have read where non ethanol gas is a key to some of our utv problems. Can I get an amen?
By didgeridoo
