     6B9BF074-5036-4696-BD54-575A70AA91E6.thumb.jpeg.c0dcc0b1dc07e275bd3c689f0e20149e.jpegFirst off the Massimo has been running great. Hasn’t missed a beat since I worked on it last.
     I’m pretty sure this has been an ongoing issue even before I got it. Towards the front of the crankcase, right of driveshaft coming out I noted a lot of oil buildup. I cleaned it up really to see if I could identify where it was coming from. It looks like there’s a seam where the two sides meet and that’s where leak is originating from.
     From what I find in the service manual it doesn’t look like there’s a gasket here. So would anyone know how this seam prevents oil leakage? The next question is how would you correct this leak? I’ve read where you don’t want to use oil leak stopper as that will most likely cause slippage on your wet clutch. Any thoughts?
Thanks, Harrison
 since they didn't use a gasket most likely they used a RTV sealant (liquid gasket)
The only solution i can think of is to take it apart, clean both gasket surfaces with brake clean and Rubbing alcohol works good at removing that stuff. and a razor blade is good for scraping paper or RTV gasket off.
I prefer to use Permatex Ultra black sealer. good up to 500 degrees F, https://www.permatex.com/products/gasketing/ultra-series-gasket-makers/permatex-ultra-black-maximum-oil-resistance-rtv-silicone-gasket-maker-4/
And for any surface that comes in contact with Gear oil i use https://www.permatex.com/products/gasketing/gasket-makers/permatex-gear-oil-rtv-gasket-maker/?locale=en_us
  • 2 years later...
ADDRESS Massimo Motors
3101 W Miller Road
Garland, TX 75041
PHONE
877-881-6376
  They are still  in Texas ,, but good luck getting any help from those  a$$holes.. Worst company on Earth..  their reviews are 1 star on every site you look at only because you cant give them a 0 stars ... BBB has hundreds of complaints  Home Depot dumped them....  Take it apart and use Black Ultra sealant   for gasket .. very  oil resistant .. works every time
    • By barticus73
      I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a  Dealer provided CFMOTO Uforce 600 at $11,500 out the door.    Are there any glaring reasons to go with the Uforce 600 at an extra $1000?  Is one model more reliable than the other?  Any input greatly appreciated.
      Thank you,
      Jerry
    • By Rschrem
    • By barticus73
      I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a Dealer sold CFMOTO Uforce 600 at $11,500 out the door.    Are there any glaring reasons to go with the Uforce 600 at an extra $1000?  Is one model more reliable than the other?  Any input greatly appreciated.
      Thank you,
      Jerry
    • By Tim n Deb
    • By Chile
      2018 Massimo MSU 700 EFI. I realize that this engine is essential the same as in all of the HISUN based Yamaha clones out there. I am in the process of performing a top end diagnosis/rebuild. I have an AMAZON top end rebuild kit on order in anticipation of this activity.
      Question 1:  When exploring the myriad of top end rebuild kits on the market for these units there are some cylinder assemblies that have "686 cm3" badging next to the cam cain tensioner boss. Others compatible with the unit do not have this badging. The existing cylinder assy does not have the 686 badging. I am assuming that this simply verifies that the cylinder assy is for a 686 cm3 engine which of course the stock 700 series HISUN engines are. Am I missing something here or is this just a manufacturer artifact? With or without the badging the application listings all indicate compatibility with the MSU 700 series engines.
      Question 2:  I have reviewed at minimum a dozen videos associated with this rebuild. To date I have not found one that deals with piston/cylinder clearance and/or ring gap verification. The advertised specifications for these various "top end rebuild kits" all indicate: Cylnider bore = 102mm and piston diameter=101.5mm. The math yields a .5mm (as in 1/2 mm) difference. That seems to be a very large piston/cylinder clearance.  I realize I am referencing advertised specs rather than emperically measured values but the numbers have gotten my attention.  I have referenced the FSM and found it to be somewhat confusing in this regard. Hopefully the experts on this forum can enlighten me as to where my observations are faulty here.
      Any and all assistance is greatly appreciated .
      Thank you all in advance,
      Chile
