My nephew has  a new 2000 tracker sxs I have told they are the same as a havoc x1000. I hope so because tracker is not supplying any pats anytime soon. He busted the lower a  arm driver side,. I found one for the havoc hope it fits.  The a arms sure are hung out there to get licked. Any one had trouble with them. Thanks in advance.
    • By Xov
    • By Tim n Deb
    • By Paul in Wisconsin
      I have a 2023 Tracker 800SX LE that I want to add a sway bar to.
      The service manual shows how to remove and reinstall the sway bar.
      I called Cabela's to try and get the saw bar.   They said they can't get one and the 800SX doesn't have one!!??  Then why is it listed in the service manual?? No answer from them.
      Have any of you found a saw bar that fits and what did it cost?
    • By Gary Odom
