On 10/6/2020 at 1:14 PM, miten000 said:
Thanks man!! I really appreciate it!!
I recommend the Ultimax UXP446 for all my clutch kits and dimension wise it is the same as the XTX2236 or 30C3750.
If you have the 800 you will need to re-shim the secondary as even in oem form they are a little slack on belt deflection.
  • 4 years later...
On 8/29/2025 at 4:33 PM, Shanegilmour said:
I ordered the Gates that you mentioned and it is way too long, like a couple inches.
You sure? Check the number again that is actually on the belt.
I can't read the # on the belt other than its a Bando belt. I ordered the Gates with the # you provided and it slides right over the clutches without even expanding the secondary. Comparison to the old one is about 2 inches shorter than the new one.
If you have a Bando belt that is NOT a Gates, Someone crossed it over and it doesn't match so you need to talk to whomever you purchased it from.
You do NOT have a Gates belt.
15 minutes ago, Shanegilmour said:
Part Numbers:30G3750 Gates belt is the one I ordered that is too long. The old belt that was on the machine when I bought it is a Bando belt.
oh ok you were giving me the oem belt not the one you got. If the 30g3750 is too long then your secondary clutch is stuck open. Show me a pic of the clutches.
7 minutes ago, Shanegilmour said:
IMG_20250831_101144.thumb.jpg.fde9c0a70335b7894b675dcd566e3ade.jpgIMG_20250831_100739.thumb.jpg.8fb165a56f3fb5fdc03343d09ad537d1.jpgPart Numbers:30G3750 Gates belt is the one I ordered that is too long. The old belt that was on the machine when I bought it is a Bando belt.
The belt number I posted is the exact replacement for that clutch setup, Now what you got I don't know.
Does it say 30G3750 on the new belt?
Posted (edited)
3 minutes ago, Shanegilmour said:
Yes. Maybe that's what my problem has been, when decelerating it bucks hard. Maybe that belt is too small?
Shoot me a pic with the new belt on there. You can adjust the secondary for belt width. Don't know if you had done that or not when you switched over.
There is a one way bearing on the primary for engine braking purposes.
Edited by Tmod
41 minutes ago, Shanegilmour said:
I already sent the belt back, I will have to reorder it and give that a try. Will message when the new belt arrives. Thank you.
What year and model is your machine as those clutches did not come on the 2015's?
So thinking of replacing the secondary clutch as it seems to be sticking a bit when the expander bolt is removed, have to tap it a bit before it will close. When trying to order they all say for 2014 - 2021, will these fit a 2013? Should I replace just the secondary or should I do both? Machine has 1000 KM on it so about 600 miles but was used mostly for plowing snow.
Just get the parts to fix the binding issue? Bushings and white spider piece in there. No wet lube, Dry film only.
So I got the new belt, it was the correct one this time, they must have put the wrong one in the box the first time. So I got the new clutches in but they are completely different than the ones on the machine. Have you ever seen this style that was on this machine and if so how do I get the inner part of the clutch out?
4 hours ago, Shanegilmour said:
Decided to try to put the primary on just to see and it won't even fit on the shaft, shaft is too big.
Yeah you got the CV Tech setup which needs different bolts and a different spacer between the driven and gearbox.
The original is the CanAm clone clutch setup.
    • By Pop Bob
      I’m ready to buy a second machine. I looked at a Gator and a Mule. They are larger than I want. Something more trail size will be better. That being said, I do not wish to purchase from a big box store again. Can anyone recommend a good dealer who sells Hisun based machines?
      Also, any thoughts on a machine with enclosed cab, HVAC, and modern electronics
      Pop Bob
    • By RBonds007
    • By Roadstar515
      Does anyone know of a bypass switch or controller. They make one for Polaris which installs into the harness that makes the ECU think it’s hooked up in normal position allowing vehicle to operate normally as if you are wearing seatbelt.
    • By Kentcoon
      I have a back-up belt in my tool box that is over 5 years old, its been exposed to air but not sunlight, is it worth putting on?
    • By Tommy2bits
      Just bought a brand new 2022 (NOS) Sector E1 with Lithium upgrade. (Single 135ah/200amp continuous). I've climbed a moderate hill in my woods probably 20 times since buying it. Today It won't climb it unless I am in Low. In High it almost makes it and then completely dies and I have to roll back down the hill. In Mid range (Max Range) I can't get 2 feet up the hill and the power output in only 100 amps, I have climbed this hill in every speed before many times. I put it on the trailer tonight and it wouldn't even get on the dang trailer in mid range. Torque is gone. That being said, when I am just cruising around in Midrange, it runs absolutely perfect with plenty of power. The only thing I did was charge it up, that is all. I charged to 100% using the charger that came with the battery. Before you think the BMS is shutting down due to overcharge protection, remember I am going UP hill so there is no regeneration AND I have done it before at 100% charge AND another big problem is that after 1 mile it is already down to 85% so it's not over charging and why is the battery draining so fast when I got 27 miles before. Battery output is fine in Low it pulls 200 amp up the hill just like normal so that doesn't point to the battery being the issue. All the individual cells on the battery are in line, so there is no dead cell either. I am tech savvy but to toward electric motors and I tried to cover all my bases. Please don't tell me basics like torque is reduced in High and Mid. The only thing I can think of is that I smelled something when I took my first drive today and I thought it was the Ebrake dragging but there was the correct amount of play in the cable and I jacked up the rear wheels and they spin freely. maybe something burned out in the motor, I do not knowm still runs great, we'll see if I have any trouble on the hills at the lake house this weekend. Maybe this is "Normal" and the settings were off before and was giving equal torque for whatever reason instead of 50% in Mid and 70% in High like the manual says....
